What is the status on your ignitor ???
The click you hear is normal ... The part shown below is your flame sensor and it is located on the cover around your burnner assembly and maybe the cause of your problem ... The way I check them is to disconnect the two wires on this part and attach them together ... I then start the dryer and wait for the ignitor to glow hot ... I then pull the two wires apart to see if the dryer fires .. If it does you know this part is faulty and needs to be replaced. ![UserPostedImage](http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfNjA5ODMzL0xQVy9zb3RvaHB0cmFwLw%3d%3d) Flame sensor - Senses flame for heat allowing gas valve to open. Part Number: AP2910747 made by WHIRLPOOL ![UserPostedImage](http://www.appliancepartspros.com/img/dot_216.gif) Our Price: $21.26 Compare at: $35.78 You Save: $14.52 ![UserPostedImage](http://www.appliancepartspros.com/img/p.gif) Availability: In Stock Order now and it will ship Today ![UserPostedImage](http://www.appliancepartspros.com/img/p.gif) Quantity ![UserPostedImage](http://www.appliancepartspros.com/img/clear.gif)
