Shoopes
#1 Posted : Monday, November 16, 2009 5:24:35 PM(UTC)
Shoopes
One night I went to bed with the dryer running. I woke up to it still running but it was ice cold. There was no heat at all. What do I order? Do I order just the heating element and the heating element wire? Is there anything else I need? Really need help.
Qtip
#2 Posted : Monday, November 16, 2009 7:16:02 PM(UTC)
Qtip
Definitely test the outlet and make sure there is 240v at the outlet. the dryer will run off of 120 but needs 240 to heat. if there is only 120 then try flipping the breaker.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
GE dryer problems (Dryer Repair)
by js072384 5/12/2012 9:15:49 PM(UTC)
Dryer Problems (Dryer Repair)
by smartin349 1/1/2012 6:35:54 AM(UTC)
by Mickey_951 10/1/2011 5:53:04 PM(UTC)
by Tsailor 3/4/2011 3:51:27 PM(UTC)
by talbot 11/2/2009 9:37:55 AM(UTC)
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 10/19/2009 11:05:38 AM(UTC)
Dryer problems mikeo (Dryer Repair)
by mikeo1899 8/4/2009 9:15:16 AM(UTC)
by berniefl 7/24/2009 6:13:21 AM(UTC)
Dryer problems HELP (Dryer Repair)
by MizzJessica 7/6/2009 10:39:42 PM(UTC)
by mbgrdido 3/24/2009 7:52:23 PM(UTC)
by janezucker 12/29/2008 9:36:33 AM(UTC)
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
by Myles.Smith 8/28/2008 6:06:48 PM(UTC)
