mbgrdido
#1 Posted : 16 years ago
mbgrdido
I was helping my son repair his electric dryer which had stopped heating. We found the dryer vent pipe to be completely clogged with lint. We replaced the metal vent pipe completely and thought this would take care of it not heating but it didn't not. Could the clogged vent have caused the dryer to overheat, which in turn would cause a relay or fuse to blow? If so how to do you figure out which one it is?
Thanks to whoever can help.
#2 Posted : 16 years ago
Here are your parts incldes a wiring diagram
Replacement parts for MAYTAG MDET236AYW | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
http://www.servicematters.com/m...ibrary/docs/16027536.pdf
If you just unplugged it when working on it, try shutting the breaker off/on a couple times slowly. Sometimes you can loose half the line without actually tripping the breaker. Still bets to check for 240 volts at the plug using a meter.
The fuse in this unit would shut off the motor so it is OK.
The next most like ly candidate is the heater, then a thermostat, then the timer and then the centrifugal switch.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
GE dryer problems (Dryer Repair)
by js072384 13 years ago
Dryer Problems (Dryer Repair)
by smartin349 13 years ago
by Mickey_951 14 years ago
by Tsailor 14 years ago
Dryer problems (Dryer Repair)
by Shoopes 15 years ago
by talbot 15 years ago
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 15 years ago
Dryer problems mikeo (Dryer Repair)
by mikeo1899 16 years ago
by berniefl 16 years ago
Dryer problems HELP (Dryer Repair)
by MizzJessica 16 years ago
by janezucker 16 years ago
Roper Dryer problems (Dryer Repair)
by b0001744 17 years ago
by Myles.Smith 17 years ago
