mbgrdido
#1 Posted : Tuesday, March 24, 2009 7:52:23 PM(UTC)
mbgrdido
I was helping my son repair his electric dryer which had stopped heating. We found the dryer vent pipe to be completely clogged with lint. We replaced the metal vent pipe completely and thought this would take care of it not heating but it didn't not. Could the clogged vent have caused the dryer to overheat, which in turn would cause a relay or fuse to blow? If so how to do you figure out which one it is?
Thanks to whoever can help.
#2 Posted : Wednesday, March 25, 2009 1:48:37 AM(UTC)
Here are your parts incldes a wiring diagram
Replacement parts for MAYTAG MDET236AYW | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16026315.pdf
http://www.servicematters.com/m...ibrary/docs/16027536.pdf
If you just unplugged it when working on it, try shutting the breaker off/on a couple times slowly. Sometimes you can loose half the line without actually tripping the breaker. Still bets to check for 240 volts at the plug using a meter.
The fuse in this unit would shut off the motor so it is OK.
The next most like ly candidate is the heater, then a thermostat, then the timer and then the centrifugal switch.
I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
GE dryer problems (Dryer Repair)
by js072384 5/12/2012 9:15:49 PM(UTC)
Dryer Problems (Dryer Repair)
by smartin349 1/1/2012 6:35:54 AM(UTC)
by Mickey_951 10/1/2011 5:53:04 PM(UTC)
by Tsailor 3/4/2011 3:51:27 PM(UTC)
Dryer problems (Dryer Repair)
by Shoopes 11/16/2009 5:24:35 PM(UTC)
by talbot 11/2/2009 9:37:55 AM(UTC)
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 10/19/2009 11:05:38 AM(UTC)
Dryer problems mikeo (Dryer Repair)
by mikeo1899 8/4/2009 9:15:16 AM(UTC)
by berniefl 7/24/2009 6:13:21 AM(UTC)
Dryer problems HELP (Dryer Repair)
by MizzJessica 7/6/2009 10:39:42 PM(UTC)
by janezucker 12/29/2008 9:36:33 AM(UTC)
Roper Dryer problems (Dryer Repair)
by b0001744 8/29/2008 9:38:02 AM(UTC)
by Myles.Smith 8/28/2008 6:06:48 PM(UTC)
