Shoopes
#1 Posted : 15 years ago
Shoopes
One night I went to bed with the dryer running. I woke up to it still running but it was ice cold. There was no heat at all. What do I order? Do I order just the heating element and the heating element wire? Is there anything else I need? Really need help.
Qtip
#2 Posted : 15 years ago
Qtip
Definitely test the outlet and make sure there is 240v at the outlet. the dryer will run off of 120 but needs 240 to heat. if there is only 120 then try flipping the breaker.
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
GE dryer problems (Dryer Repair)
by js072384 13 years ago
Dryer Problems (Dryer Repair)
by smartin349 13 years ago
by Mickey_951 14 years ago
by Tsailor 14 years ago
by talbot 15 years ago
Asko condenser dryer problems (Dryer Repair)
by Marv Sumner 16 years ago
Dryer problems mikeo (Dryer Repair)
by mikeo1899 16 years ago
by berniefl 16 years ago
Dryer problems HELP (Dryer Repair)
by MizzJessica 16 years ago
by mbgrdido 16 years ago
by janezucker 16 years ago
Roper Dryer problems (Dryer Repair)
by b0001744 17 years ago
by Myles.Smith 17 years ago
