One night I went to bed with the dryer running. I woke up to it still running but it was ice cold. There was no heat at all. What do I order? Do I order just the heating element and the heating element wire? Is there anything else I need? Really need help.
Definitely test the outlet and make sure there is 240v at the outlet. the dryer will run off of 120 but needs 240 to heat. if there is only 120 then try flipping the breaker.
