mcomer
#1 Posted : Monday, November 16, 2009 7:30:21 PM(UTC)
mcomer
Agitator will not turn. Heard a snap when starting the final spin cycle and that's all she wrote. There is a small pile of black debris under the coupling between the motor and the transmission. The motor seems to run fine in response to the controls. Should I finally just replace this baby?
Thanks, Mike
PS. Can anyone tell me how old she is? Got her with the house.<g>
sidfink43
#2 Posted : Tuesday, November 17, 2009 7:17:59 PM(UTC)
sidfink43
Well, you can spend at least $350.00 including tax and delivery for a new machine, or you can spend about $16.00 including shipping on this part and take an hour of your time and repair it and have a machine functioning as it was before. Your choice.
Here is the coupling.
Part number: AP3963893
and here is a video which will show you how to make the repair.
YouTube - Direct Drive Washing Machine Repair Video Tutorial *Watch in HIGH Quality!*
Submit a serial number and we can tell you how old it is. Probably around 7-10.
mcomer
#3 Posted : Wednesday, November 18, 2009 6:19:22 AM(UTC)
mcomer
Sid...,
Thanks so much for that. And what a terrific video! You make it a touch choice.<G>
I'll go over my daughter's and drop the motor this AM. However, there was something else I forgot. I could not tourn the agitator at all. Is this normal given a snapped coupling?
SN is - CF2001747
Thanks again, Mike
sidfink43
#4 Posted : Wednesday, November 18, 2009 8:04:55 AM(UTC)
sidfink43
The agitator should not be hung up, but let's see how things are after you look at the coupling. It may be that your transmission or something else in that area failed, causing the coupling to fail in which case replacement may well be in order given the fact that your machine dates from 1996.
When you get the motor off see if you can turn the shaft from the transmission in each direction.
mcomer
#5 Posted : Wednesday, November 18, 2009 7:35:33 PM(UTC)
mcomer
Coupling sheared. Transmission shaft turns easily in either direction...? Agitator still doesn't turn.
Thanks, Mike
sidfink43
#6 Posted : Wednesday, November 18, 2009 7:39:43 PM(UTC)
sidfink43
Well, cause I like repairing things and because the coupling is inexpensive I would put one on and see if she runs. I think you will be fine.
mcomer
#7 Posted : Wednesday, November 18, 2009 7:45:20 PM(UTC)
mcomer
Sid,
Thanks. Ordering it now.<g> Will let you know...?
Mike
sidfink43
#8 Posted : Wednesday, November 18, 2009 8:02:48 PM(UTC)
sidfink43
Sounds good.
Since you are worried about it, I would also take off the agitator and make sure the dogs or any other internal part are hung up. You should be able to do this by taking off the top and the cap, and taking out the screw that holds it down.
mcomer
#9 Posted : Wednesday, November 18, 2009 8:08:49 PM(UTC)
mcomer
Done that. No problem there. If there is an issue it's deeper. I have some experience of replacing the dogs on another machine, and boy did that make a difference.<G>
M
Frigidair Front Load Washer Spin Basket is seized (Washer Repair)
by Mariawf 3/23/2013 6:43:03 PM(UTC)
Hub lock nut seized (Washer Repair)
by david85326 2/12/2013 10:26:23 PM(UTC)
Whirlpool Drum Seized (Dryer Repair)
by Daniel J 1/3/2012 11:07:32 AM(UTC)
Seized evaporator fan (Refrigerator & Freezer Repair)
by pelagikos 5/26/2010 9:37:33 AM(UTC)
Seized washer (Washer Repair)
by dgpwk 2/21/2010 4:52:45 PM(UTC)
Agitator seems to be seized to drum. (Washer Repair)
by kennewickman 4/22/2009 11:01:33 PM(UTC)
