Agitator will not turn. Heard a snap when starting the final spin cycle and that's all she wrote. There is a small pile of black debris under the coupling between the motor and the transmission. The motor seems to run fine in response to the controls. Should I finally just replace this baby? Thanks, Mike PS. Can anyone tell me how old she is? Got her with the house.<g>
Well, you can spend at least $350.00 including tax and delivery for a new machine, or you can spend about $16.00 including shipping on this part and take an hour of your time and repair it and have a machine functioning as it was before. Your choice. Here is the coupling. Part number: AP3963893
Sid...,
Thanks so much for that. And what a terrific video! You make it a touch choice.<G>
I'll go over my daughter's and drop the motor this AM. However, there was something else I forgot. I could not tourn the agitator at all. Is this normal given a snapped coupling?
SN is - CF2001747
Thanks again, Mike
The agitator should not be hung up, but let's see how things are after you look at the coupling. It may be that your transmission or something else in that area failed, causing the coupling to fail in which case replacement may well be in order given the fact that your machine dates from 1996.
When you get the motor off see if you can turn the shaft from the transmission in each direction.
Coupling sheared. Transmission shaft turns easily in either direction...? Agitator still doesn't turn. Thanks, Mike
Well, cause I like repairing things and because the coupling is inexpensive I would put one on and see if she runs. I think you will be fine.
Sid,
Thanks. Ordering it now.<g> Will let you know...?
Mike
Sounds good.
Since you are worried about it, I would also take off the agitator and make sure the dogs or any other internal part are hung up. You should be able to do this by taking off the top and the cap, and taking out the screw that holds it down.
Done that. No problem there. If there is an issue it's deeper. I have some experience of replacing the dogs on another machine, and boy did that make a difference.<G> M
