krislinda
#1 Posted : Saturday, February 23, 2008 12:35:56 PM(UTC)
krislinda
dryer works well but squeeks like a fan belt slipping in a car. Replace belt, idler pulleyand front glides but did not fix the problem. Rollers seem ok. Any clues what else might be making that kind of noise?? Kris.
ApplianceJunk
#2 Posted : Sunday, February 24, 2008 10:49:19 AM(UTC)
ApplianceJunk
It could be the motor. You can run just the motor on air dry cycle with the drum out to see.
You could also try and put some WD40 on the drum rollers. Often times they are ok, just a little dry.
Maytag Dryer shutting off after 2 minutes (Dryer Repair)
by Guest 11/9/2023 4:45:11 AM(UTC)
maytag dryer MEDC200XW1 (Dryer Repair)
by patnok 9/4/2023 8:02:13 AM(UTC)
Replaced belt, idler pulley, and rollers and now Maytag Dryer Wont Start (Dryer Repair)
by Guest 11/29/2022 8:43:07 PM(UTC)
Maytag Dryer MGD7230HW2 LP CONVERSION HELP!! (Dryer Repair)
by prodigey 10/14/2022 3:54:00 AM(UTC)
Maytag dryer (Mode MEDC300XW1) not starting, but runs only in Wrinkle Prevent cycle. (Dryer Repair)
by Guest 7/28/2022 6:31:22 PM(UTC)
Maytag dryer won't stop on timed dry (Dryer Repair)
by eaglemtn 11/11/2021 5:35:16 PM(UTC)
Maytag Dryer Slow to Spin after parts replacement (Dryer Repair)
by steelwindmachine 8/18/2021 5:58:15 AM(UTC)
Maytag Dryer not drying. Flame shuts off after 20-30 seconds (Dryer Repair)
by jbschwartz 6/27/2021 4:54:19 PM(UTC)
Maytag dryer MDE9316ATA (Dryer Repair)
by Guest 5/1/2021 3:45:42 PM(UTC)
Maytag Dryer (Bravos) (Dryer Repair)
by Kap61 3/29/2021 4:03:51 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
Maytag Dryer Starts But No Heat (Dryer Repair)
by boonie785 6/1/2020 3:32:33 PM(UTC)
Maytag dryer stops early (Dryer Repair)
by J-fixtit 5/28/2020 6:59:15 PM(UTC)
Maytag dryer dont start (Dryer Repair)
by jzemer 5/16/2020 5:58:30 PM(UTC)
MAYTAG dryer loud squealing/squeaking (Dryer Repair)
by joenobodyyet 3/24/2020 1:27:25 PM(UTC)
