cwsunderland
#1 Posted : Sunday, April 4, 2021 5:00:24 AM(UTC)
cwsunderland
United States
I have a Whirlpool double oven wod51ec0hs (about 2 years old) and after I did a self cleaning cycle on the bottom oven (which I've been reading is like a kill switch) it will not turn on and heat. I had a technician come out and he replaced a small circular device in the back of the oven (thermal fuse?) and also replaced one of the control boards (if you are facing the oven, it is the right one). Neither of these fixed the issue. He is coming back out to replace the other control board. I'm just wondering if this doesn't fix the issue, what else could be the problem with the bottom oven not heating up?
Chris
Edited by user Sunday, April 4, 2021 5:02:26 AM(UTC)  | Reason: Not specified
Whirlpool Double oven diagnostic mode (Oven Repair (including Ranges and Cooktops))
by webjunk78230 8/29/2022 1:37:43 PM(UTC)
Whirlpool double oven RBD305PVS02 no display, no heat, lights work (Oven Repair (including Ranges and Cooktops))
by Guest 1/5/2022 7:05:37 AM(UTC)
Whirlpool Double Oven, RBD305PRS00, no display, oven dead (Oven Repair (including Ranges and Cooktops))
by steveg_nh 12/31/2021 7:23:33 AM(UTC)
Whirlpool double oven RBD305PDQ14 (Oven Repair (including Ranges and Cooktops))
by ReeseReed0415 4/21/2020 7:15:22 AM(UTC)
Whirlpool double oven mounted in wall cabinets (Oven Repair (including Ranges and Cooktops))
by Redeyebob 12/30/2019 10:31:52 AM(UTC)
My whirlpool double oven won’t turn on (Oven Repair (including Ranges and Cooktops))
by Zuvdog 12/23/2019 8:38:06 AM(UTC)
Whirlpool Double Oven - Bottom Not Working (Oven Repair (including Ranges and Cooktops))
by kanderna 3/24/2018 9:58:57 AM(UTC)
Dead Display Whirlpool Double Oven (Oven Repair (including Ranges and Cooktops))
by chatenever 12/14/2017 6:51:55 AM(UTC)
Whirlpool Double Oven - Control Board & Door latch assembly??? (Oven Repair (including Ranges and Cooktops))
by Bhauer 6/6/2017 7:09:43 PM(UTC)
Whirlpool double oven display blank (Oven Repair (including Ranges and Cooktops))
by krupp 3/26/2016 7:01:29 AM(UTC)
How do I access control panel - Whirlpool double oven (Oven Repair (including Ranges and Cooktops))
by technogal54 3/6/2016 8:32:18 AM(UTC)
Whirlpool Double Oven Error Code - Help (E6 F2 and E1 F2) (Oven Repair (including Ranges and Cooktops))
by trvsthbdx 8/24/2015 7:46:08 PM(UTC)
Whirlpool Double Oven not working (Oven Repair (including Ranges and Cooktops))
by velazedv 6/16/2015 12:16:58 PM(UTC)
Whirlpool Double Oven Blank Display (Oven Repair (including Ranges and Cooktops))
by RDLearned 1/26/2015 3:20:49 PM(UTC)
Whirlpool Double Oven. No Power, No Beeps (Refrigerator & Freezer Repair)
by pssmetana 1/21/2015 6:39:53 PM(UTC)
