I have a Whirlpool double oven wod51ec0hs (about 2 years old) and after I did a self cleaning cycle on the bottom oven (which I've been reading is like a kill switch) it will not turn on and heat. I had a technician come out and he replaced a small circular device in the back of the oven (thermal fuse?) and also replaced one of the control boards (if you are facing the oven, it is the right one). Neither of these fixed the issue. He is coming back out to replace the other control board. I'm just wondering if this doesn't fix the issue, what else could be the problem with the bottom oven not heating up? Thanks Chris Edited by user Sunday, April 4, 2021 5:02:26 AM(UTC)
| Reason: Not specified
