johnh@echoetching.com
#1 Posted : Tuesday, March 27, 2018 12:50:30 PM(UTC)
A fin fell off the drum in the dryer. Can it be fixed?
ThatGuy
#2 Posted : Friday, March 30, 2018 3:34:56 PM(UTC)
ThatGuy
Groups: Expert
United States
Probably. Most are attached with screws. Do you have a model number?
thorning
#3 Posted : Monday, April 2, 2018 10:59:44 AM(UTC)
thorning
These can be replaced easily IF the screw holes in the plastic fin are still in decent condition. The original screw may need to be replaced with a slightly longer one. When you reattach it use Loctite on the screw threads. Also check the other fins to see if the screws are tight. If they are a little loose take them out one at a time and use some Loctite on them when you retighten them.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by gtravis331 4/13/2014 6:01:38 PM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
Dryer Problem Again (Dryer Repair)
by dstoliby 7/30/2012 11:37:40 AM(UTC)
