gtravis331
#1 Posted : Sunday, April 13, 2014 6:01:38 PM(UTC)
gtravis331
dryer starts when start button is pushed but stops when released. i taped start button down and the dryer performed normally. whats the problem?
#2 Posted : Monday, April 14, 2014 2:16:55 AM(UTC)
Parts for Kenmore Dryer 11063932101 - AppliancePartsPros.com
The motor relay should close and keep the motor running when you release the start button.
Could be the relay itself.
Easiest way to check this is to unplug the unit and swap the heater and motor relays. Then plug it in and give it a try.
If it now stays running but you have no heat then you know it is the relay.
I believe the two relays are the same but double check this.
If the above changes nothing then odds are that the control board is toast.
File Attachment(s):
63932101.pdf (293kb) downloaded 9 time(s).
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 4/15/2023 1:25:03 PM(UTC)
Front load dryer problem (Dryer Repair)
by Guest 4/29/2021 5:08:47 AM(UTC)
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 11/22/2020 12:41:02 PM(UTC)
Dryer problem (Dryer Repair)
by johnh@echoetching.com 3/27/2018 12:50:30 PM(UTC)
by al kopsick 10/8/2017 11:08:40 AM(UTC)
Cabrio dryer problems (Dryer Repair)
by artsalena 1/19/2017 2:37:30 PM(UTC)
Dryer Problem (Dryer Repair)
by clcw199 11/5/2015 9:07:48 AM(UTC)
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 10/19/2015 9:06:20 AM(UTC)
by Qzzy 3/17/2014 8:01:45 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 10/22/2013 3:21:12 AM(UTC)
by Pat Ranguette 8/26/2013 5:41:29 PM(UTC)
by forenz 7/2/2013 1:34:33 PM(UTC)
by Hoovdawg3 6/8/2013 3:42:16 PM(UTC)
Dryer Problem Again (Dryer Repair)
by dstoliby 7/30/2012 11:37:40 AM(UTC)
