Dryer making a thumping/surging type sound, even when the dryer belt is unhooked.
Here are your parts Parts for Frigidaire AEQ6000ES2 Dryer - AppliancePartsPros.comSince is does this with the drum not turning I would check the blower wheel. If it is OK then all that is left is the motor. I am assuming that it also does this with the vent disconnected. If not then check it with the vent disconnected. |
THIS FORUM IS DEAD!!!!!!! |
