clcw199
#1 Posted : 9 years ago
clcw199
Dryer making a thumping/surging type sound, even when the dryer belt is unhooked.
#2 Posted : 9 years ago
Parts for Frigidaire AEQ6000ES2 Dryer - AppliancePartsPros.com
Since is does this with the drum not turning I would check the blower wheel.
If it is OK then all that is left is the motor.
I am assuming that it also does this with the vent disconnected.
If not then check it with the vent disconnected.
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 2 years ago
Front load dryer problem (Dryer Repair)
by Guest 4 years ago
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Dryer problem (Dryer Repair)
by johnh@echoetching.com 7 years ago
by al kopsick 7 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 9 years ago
by gtravis331 11 years ago
by Qzzy 11 years ago
clothes dryer problem (Dryer Repair)
by jsullivan652 11 years ago
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 11 years ago
by Pat Ranguette 12 years ago
Dryer Problem (Dryer Repair)
by forenz 12 years ago
by Hoovdawg3 12 years ago
Dryer Problem Again (Dryer Repair)
by dstoliby 13 years ago
