Pat Ranguette
#1 Posted : 11 years ago
Pat Ranguette
Just replaced the heat element but sensor dry cycle not working, timed dry cycle does work but have to run 2 - 3 times to get clothes dry. Not sure what to check next.
HumboldtRepairMan
#2 Posted : 11 years ago
HumboldtRepairMan
First off when you replaced the heat element there's 2 wires going to the moisture bars on the inside front of the unit i bet you didn't reattach those wires, it's a common mistake. Also clean those bars up with a piece of sandpaper or a metal bristle brush they get fabric softener and detergent residue that affects the moisture sensor cycle. Easy way to test if your moisture sensing is working properly, put NO clothes in unit run it for 10-15 minutes if it shuts off by itself it's working properly. Good luck
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 2 years ago
Front load dryer problem (Dryer Repair)
by Guest 4 years ago
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Dryer problem (Dryer Repair)
by johnh@echoetching.com 7 years ago
by al kopsick 7 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
Dryer Problem (Dryer Repair)
by clcw199 9 years ago
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 9 years ago
by gtravis331 11 years ago
by Qzzy 11 years ago
clothes dryer problem (Dryer Repair)
by jsullivan652 11 years ago
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 11 years ago
by forenz 12 years ago
by Hoovdawg3 12 years ago
Dryer Problem Again (Dryer Repair)
by dstoliby 12 years ago
