Medee
#1 Posted : Saturday, April 8, 2017 5:26:00 PM(UTC)
Medee
Dryer wasn't heating replaced fuse & heating element. Dryer comes on & trips breaker. Any ideas? Could the wires be crossed
PNWDrew
#2 Posted : Sunday, April 9, 2017 12:59:17 PM(UTC)
PNWDrew
Short answer, yes you could miswire this and cause a short that trips your breaker.
Does it trip the breaker as soon as you start it or when you try to just power it up? If it powers up normally try to start air dry and see if the same happens, in air dry the computer will not (or should not) try to close the relay that supplies it's side of the 120V to the element.
Also did you change the entire element duct DC97-14486A?
Just FYI: Samsung parts diagrams are unreliable due to poor translation, some Samsung parts diagrams use terminology that is used for distinctly different parts in all other brands.
For instance what we would call the "thermal cutoff" on the element duct most dryers is labeled as a "thermal fuse" on some Samsung diagrams. The actual part we'd call a thermal fuse is the common term for a safety thermostat on the blower housing that opens the motor circuit and stops the machine from running.
The confusing terminology makes discussing Samsung appliance parts difficult at times. You may find it easier to use the part # and/or describe the location.
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
samsung dryer Dv48H (Dryer Repair)
by Guest 2/27/2024 6:11:07 PM(UTC)
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
Samsung Dryer Test Mode (Dryer Repair)
by stanw 8/8/2023 2:36:51 PM(UTC)
Samsung Dryer possibly in flood throwing HC code (Dryer Repair)
by QuickPuppy 2/16/2023 7:41:27 AM(UTC)
Samsung dryer starts but won't turn drum or heat (Dryer Repair)
by coach_hall_42 1/22/2023 1:39:56 PM(UTC)
Samsung dryer stuck in continuous cycle (Dryer Repair)
by Guest 8/26/2022 6:18:39 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
Runs 3Min Stops-OR-Runs & Doesn't heat Samsung Dryer DV42H5000EW/A3-0000 (Dryer Repair)
by Guest 2/18/2022 11:57:14 AM(UTC)
Samsung dryer conversion to 50hz (Dryer Repair)
by Hlaudio 1/13/2022 2:57:31 AM(UTC)
Samsung dryer DV42H5200 still not heating after replacing all components (Dryer Repair)
by Guest 1/9/2022 11:26:52 AM(UTC)
Samsung Dryer HE error (Dryer Repair)
by hoagieh 10/23/2021 1:17:45 PM(UTC)
Samsung Dryer no heat (Dryer Repair)
by Guest 10/5/2021 5:41:36 PM(UTC)
Samsung Dryer Error Code "HE" (Dryer Repair)
by czechmka 7/7/2021 11:01:22 AM(UTC)
Samsung dryer stopped heating (Dryer Repair)
by Jakesnow 6/11/2021 11:46:23 AM(UTC)
