Issue: drying running but no heat
Troubleshooting 1. Got my volt meter out and tested the DC96-00887A Thermal fuse. No connectivity. Replaced the first time. 2. the Dryer works on one load. DC96-00887A Thermal fuse blows again 3. Replaced the Thermal fuse and Thermostat DC47-00016A - again the thermal fuse blows again 4. Replaced the thermal fuse, Thermostat, DC32-00007A Thermistor and the DC47-00019A Dryer Heating Element - again the thermal fuse blows again. 5. Checked the voltage on the terminal block where your dryer power cord. One side 120 volts the other side 120volts and both sides getting 240 volts. I am running out of ideas. Please help.
