Sfs_cds07@yahoo.com
#1 Posted : 8 years ago
Sfs_cds07@yahoo.com
Maytag oven takes almost an hour to reach 350 degrees. I am a rookie at this and purchased this used oven that apparently has some issues I was not told about. Yes it did work when I purchased but and still works but not like it should. IMO the flame for oven is small, broiler not lighting at all but I smell the gas so safety valve is opening. Stovetop works fine. Any Help is greatly appreciated.:confused:
ThatGuy
#2 Posted : 8 years ago
ThatGuy
Groups: Expert
United States
There is something wrong with your model number. I used this one to look up your range.
Parts for Maytag MGR4452ADW Range - AppliancePartsPros.com
Most likely you have a weak igniter. Here is the part number for this model number
MGR4452ADW
http://www.appliancepartspros.com/whirlpool-oven-ignitor-74007498-ap4096256.html
Electric Oven Slow to Heat Up (Oven Repair (including Ranges and Cooktops))
by deere420 8 years ago
oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ndobois@yahoo.com 11 years ago
GE XL44 Gas Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Vinnyboy6527 12 years ago
by FoByFo 13 years ago
Samsung Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by lymansbay 14 years ago
gas oven slow to heat up/achieve desired temperature (Oven Repair (including Ranges and Cooktops))
by FPF 14 years ago
GE XL44 Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by solo12357 14 years ago
Electric oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Fairbob 16 years ago
Oven slow to heat up but broiler works (Oven Repair (including Ranges and Cooktops))
by drcain 17 years ago
Oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ladbroke 17 years ago
