Sfs_cds07@yahoo.com
#1 Posted : Wednesday, November 23, 2016 5:28:28 PM(UTC)
Sfs_cds07@yahoo.com
Maytag oven takes almost an hour to reach 350 degrees. I am a rookie at this and purchased this used oven that apparently has some issues I was not told about. Yes it did work when I purchased but and still works but not like it should. IMO the flame for oven is small, broiler not lighting at all but I smell the gas so safety valve is opening. Stovetop works fine. Any Help is greatly appreciated.:confused:
ThatGuy
#2 Posted : Wednesday, November 23, 2016 6:15:03 PM(UTC)
ThatGuy
Groups: Expert
United States
There is something wrong with your model number. I used this one to look up your range.
Parts for Maytag MGR4452ADW Range - AppliancePartsPros.com
Most likely you have a weak igniter. Here is the part number for this model number
MGR4452ADW
http://www.appliancepartspros.com/whirlpool-oven-ignitor-74007498-ap4096256.html
Electric Oven Slow to Heat Up (Oven Repair (including Ranges and Cooktops))
by deere420 1/30/2017 5:34:03 AM(UTC)
oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ndobois@yahoo.com 10/29/2013 10:55:04 AM(UTC)
GE XL44 Gas Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Vinnyboy6527 12/17/2012 12:17:27 PM(UTC)
by FoByFo 6/7/2012 7:04:34 PM(UTC)
Samsung Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by lymansbay 4/19/2011 2:36:56 PM(UTC)
gas oven slow to heat up/achieve desired temperature (Oven Repair (including Ranges and Cooktops))
by FPF 1/1/2011 1:09:12 PM(UTC)
GE XL44 Oven slow to heat (Oven Repair (including Ranges and Cooktops))
by solo12357 12/18/2010 9:49:56 AM(UTC)
Electric oven slow to heat (Oven Repair (including Ranges and Cooktops))
by Fairbob 9/15/2008 5:50:52 PM(UTC)
Oven slow to heat up but broiler works (Oven Repair (including Ranges and Cooktops))
by drcain 12/16/2007 12:03:05 PM(UTC)
Oven slow to heat up (Oven Repair (including Ranges and Cooktops))
by ladbroke 12/11/2007 8:43:12 PM(UTC)
