robertwyatt93
#1 Posted : Tuesday, January 12, 2016 11:32:53 AM(UTC)
robertwyatt93
O.K. I have a whirlpool Electric Dryer at first it was coding E1 so I changed out the Thermal Mister fixed the coding error but wouldn't heat up. so I changed out the Heater element and the Thermal Cut-Off. Still is not heating up so i changed out the Thermal Fuse. Its still not heating up what else is there that could cause the problem?
#2 Posted : Wednesday, January 13, 2016 1:34:24 AM(UTC)
Parts for Whirlpool GEW9868KL0 Dryer - AppliancePartsPros.com
First I would check the power.
Use the 750 volt AC scale.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Unplug the unit.
Using the lowest scale on the meter (usually 200 ohms) measure from the red wire on the thermal cutoff to the red wire on the heater.
Should be in the 8 to 12 ohms range.
Check the thermistor. It should be about 10,000 ohms. Use the 20 K scale (20,000 ohms)
If both are OK you will have to do a live test.
Be very very careful.
If you are uncomfortable doing this get a friend who has electrical experience or a pro in.
Unplug the red wire from the heater.
Make sure that it cannot short to anything else while you do your test.
Plug the unit in and start a heating cycle.
You should see 120 volts between the heater connector and Neutral/ground/heater case.
If not then the control board is probably bad.
If OK.
Measure from the red wire you disconnected to the heater case.
You shoul also see 120 volts here.
If not there is a problem with the centrifugal switch on the motor.
Unplug the unit and check the wires at the switch.
It is not that uncommon for one of them to come loose.
Also check that the motor is clean.
If all OK then the motor is probably the culprit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool gas oven lights but won't heat to temperature (Oven Repair (including Ranges and Cooktops))
by mikepol2 10/28/2021 5:13:06 AM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
GE Microwave (JE1860BH04) won't heat AND table won't turn (Microwave Repair)
by CoryH 2/17/2021 6:45:11 AM(UTC)
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Maytag MGD9700SQ0 Won't Heat/Open Gas Valve (Dryer Repair)
by jpc315 11/9/2020 2:59:17 PM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Maytag Dryer *usually* won't heat (Dryer Repair)
by ab52 6/12/2020 12:20:59 PM(UTC)
GE dryer runs but won't heat up (Dryer Repair)
by bristles 5/5/2020 5:44:54 PM(UTC)
GE Cafe CT9050SH1SS won't heat to desired temperature (Oven Repair (including Ranges and Cooktops))
by gvfixit 4/19/2020 3:22:33 PM(UTC)
Outside element in dual element won't heat, even after replacing (Oven Repair (including Ranges and Cooktops))
by RyanSha 9/2/2019 8:11:47 AM(UTC)
Kenmore Electric Wall Oven 790.41003603 - Broil AND Bake elements won't heat (Oven Repair (including Ranges and Cooktops))
by acehigh21 7/28/2019 11:14:25 AM(UTC)
