Parts for Whirlpool GEW9868KL0 Dryer - AppliancePartsPros.comSee the attachment for the tech sheet.
First I would check the power.
Use the 750 volt AC scale.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Unplug the unit.
Using the lowest scale on the meter (usually 200 ohms) measure from the red wire on the thermal cutoff to the red wire on the heater.
Should be in the 8 to 12 ohms range.
Check the thermistor. It should be about 10,000 ohms. Use the 20 K scale (20,000 ohms)
If both are OK you will have to do a live test.
Be very very careful.
If you are uncomfortable doing this get a friend who has electrical experience or a pro in.
Unplug the red wire from the heater.
Make sure that it cannot short to anything else while you do your test.
Plug the unit in and start a heating cycle.
You should see 120 volts between the heater connector and Neutral/ground/heater case.
If not then the control board is probably bad.
If OK.
Measure from the red wire you disconnected to the heater case.
You shoul also see 120 volts here.
If not there is a problem with the centrifugal switch on the motor.
Unplug the unit and check the wires at the switch.
It is not that uncommon for one of them to come loose.
Also check that the motor is clean.
If all OK then the motor is probably the culprit.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
