sobrien224
#1 Posted : Monday, November 9, 2015 9:55:17 AM(UTC)
sobrien224
The display only lights up when I turn the burner on. When I turn the burner on I can access all of the controls, however, the burners do not heat up nor does the oven/broiler. When I turn the burner off, the display disappears. I have tried turning off the breaker for 1-2 min. to try and reset but nothing changes.
#2 Posted : Monday, November 9, 2015 1:18:21 PM(UTC)
This sounds like a power problem.
You have probably lost one side of the line. When you turn on an element this provides a path for the other side of the line to power up your display/timer.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
Whirlpool Electric Range Cooktop Will not Heat (Oven Repair (including Ranges and Cooktops))
by mraupie17 9/2/2023 9:50:45 AM(UTC)
Problem with Whirlpool electric range (won't heat properly anymore) (Oven Repair (including Ranges and Cooktops))
by phillydee 4/20/2023 6:10:35 AM(UTC)
Whirlpool electric range GR563LXSS (Oven Repair (including Ranges and Cooktops))
by longtimealaskan 3/6/2023 9:47:00 PM(UTC)
Samsung electric range bake and broil do not work (Oven Repair (including Ranges and Cooktops))
by Guest 12/20/2022 2:07:19 PM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Westinghouse Electric Range Model KF341R (Appliance Parts)
by GEman 5/28/2022 9:09:03 AM(UTC)
GE electric range - nothing works but the clock (Oven Repair (including Ranges and Cooktops))
by Jelltronic 5/15/2022 6:28:03 AM(UTC)
Frigidaire LGEF3043KFM Electric Range Uneven Heat (Oven Repair (including Ranges and Cooktops))
by Asweateria 2/27/2022 9:32:41 PM(UTC)
Samsung electric range (Oven Repair (including Ranges and Cooktops))
by MELLIOTT 2/8/2022 6:38:17 AM(UTC)
LG Electric Range Overheating (Oven Repair (including Ranges and Cooktops))
by jenvee 1/25/2022 7:20:52 AM(UTC)
kenmore electric range 79097459802 (Oven Repair (including Ranges and Cooktops))
by Melissadimas 1/9/2022 9:07:08 PM(UTC)
replacing latch, door on Kitchen Aid electric range series II (Oven Repair (including Ranges and Cooktops))
by WSCHUMANN 7/12/2021 6:02:36 AM(UTC)
GE Electric Range Keeps turning off (Oven Repair (including Ranges and Cooktops))
by Guest 5/7/2021 9:58:17 AM(UTC)
REPLACE OVEN DOOR OUTER GLASS FRIDGAIR ELECTRIC RANGE MODELFEF357BBA (Oven Repair (including Ranges and Cooktops))
by Guest 5/3/2021 12:14:15 PM(UTC)
