it runs and goes threw the washing, then it stops midway. There's water in the tub.
There should be tech notes inside the lower service panel. Focus on generating error codes and testing the speed control board, the door lock assembly and the wiring beween those components and the main control unit. Make sure everyting is seated tightly.
Good luck
