2 Pages12>
Steve Carlini
#1 Posted : Thursday, July 12, 2012 6:46:08 AM(UTC)
Steve Carlini
Hi My kitchen aid gas oven Model KGST307 9754288, started to take a long time to heat up on the order of 30-40 minutes, I figured it was the ignitors so I replaced both the oven and broiler ignitors. This did not correct the problem. What I wanted assistance was a trouble shooting guide to check the voltage to see if control panel is faulty. I wanted to also check voltage where ignitors plus in gas switch. If you can help it would be much appreciated thanks Steve
Simon / APP Team
#2 Posted : Thursday, July 12, 2012 10:54:56 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to monitor the burners while in preheat.Are they fully ignited?
Check the displayed temperature and real one in the oven (use the dependable thermometer).
Using the multimeter check the temp. sensor resistance.
At the room temp. approx.1100 ohms.
Thank you. Post the results.
Simon.
Steve Carlini
#3 Posted : Thursday, July 12, 2012 11:27:59 AM(UTC)
Steve Carlini
Hi the oven /brower burners are not lit and the ingators are at room temp the panes states on low and no temp reading , onlt temp reading is teh set temp of 350 degrees. Th estove top burners are working fine thansk Steve
Simon / APP Team
#4 Posted : Thursday, July 12, 2012 11:41:07 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the ignitors glow?
Simon.
Steve Carlini
#5 Posted : Thursday, July 12, 2012 1:15:30 PM(UTC)
Steve Carlini
Simon Hi thanks for getting back to me, the ignitors do not glow and are at room temp, I am thinking that the control circuit is not sending signal to them, I did replace both ignitors and verified continuity prior to installation Thanks Steve
Simon / APP Team
#6 Posted : Thursday, July 12, 2012 3:00:16 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I need the complete model number. You are missing 4 digits.
Then I'll be able to get you the right part and test points.
Simon.
Steve Carlini
#7 Posted : Thursday, July 12, 2012 3:02:37 PM(UTC)
Steve Carlini
Simon Thanks KGST307HBS6 appreciate the support Steve
Steve Carlini
#8 Posted : Thursday, July 12, 2012 3:28:48 PM(UTC)
Steve Carlini
simon Hi I removed the control panel and when looking at the back I see the microcomputer AP3137864 depicted by item number 2 on your diagram but I did not see the microcomputer AP3085940 depicked by item number 10 on your diagram? Note I did not remove the microcomputer AP3237864 from the control panel yet was waiting till I hear from you on voltages(is it behind it)? Thanks Steve
Simon / APP Team
#9 Posted : Thursday, July 12, 2012 3:29:33 PM(UTC)
Simon / APP Team
Groups: APP Team
OK.
You need a multimeter. Turn the power off.
Open the control panel. Get to the power relay board and locate the contacts P2,P8,P1-1.
Turn the oven to Bake and check the voltage P1-1 and P1-6.
You should have 120VAC.If not - check the bi-metal thermostat with black wires.
Next check for 120VAC between P2 and P1-1.
Set the oven for Broil and check P8 to P1-1.
If no voltage - replace the relay board
Part number: 9754378
Here are the breakdown diagrams and Replacement parts for Whirlpool KGST307HBS6 RANGE | AppliancePartsPros.com
Thank you.
Simon.
Steve Carlini
#10 Posted : Thursday, July 12, 2012 4:07:36 PM(UTC)
Steve Carlini
Simon I have the control panel removed and rolled back and I do not see the panel you describe which is item 10 on diagram I only see item 2 from diasgram the ELECTRONIC OVEN CONTROL UNIT, I circuit baord and when I remove P4 and P5 from that assembly, I see LCD panel behind. It that AP3085940 located else where in oven you can call me at 508-523-9391 to discuss thanks Steve
2 Pages12>
