I HAVE A FRONT LOAD FTF2140es3 when I turn it on it works for 3 seconds and seats for A MINUT RESTART FOR 3 second stops HELP!!!!! I replaced the top control board, door locker is good, pressure switch,is good, drain pump is good, what else can I do,,PLEASE HELP ME THANK YOU
Well darn, that should have fixed it. Use the tech notes inside the lower panel to test the motor/speed control board. But first check all of the wiring and make certain the door lock wiring is okay.
Well darn, what you did should have fixed it. Use the tech notes inside the lower service panel to test the motor/speed control board. And make sure the wiring to and from the door lock assembly is good and the connections are tight.
