jose silva
#1 Posted : Saturday, May 30, 2015 12:05:01 PM(UTC)
jose silva
I HAVE A FRONT LOAD FTF2140es3 when I turn it on it works for 3 seconds and seats for A MINUT RESTART FOR 3 second stops HELP!!!!!
I replaced the top control board, door locker is good, pressure switch,is good, drain pump is good, what else can I do,,PLEASE HELP ME THANK YOU
sidfink43
#2 Posted : Sunday, May 31, 2015 5:17:04 PM(UTC)
sidfink43
Well darn, that should have fixed it. Use the tech notes inside the lower panel to test the motor/speed control board. But first check all of the wiring and make certain the door lock wiring is okay.
sidfink43
#3 Posted : Sunday, May 31, 2015 5:18:32 PM(UTC)
sidfink43
Well darn, what you did should have fixed it. Use the tech notes inside the lower service panel to test the motor/speed control board. And make sure the wiring to and from the door lock assembly is good and the connections are tight.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Frigidaire dishwasher code A (Dishwasher Repair)
Belarus Evandtam 6/27/2024 5:11:41 PM(UTC)
Frigidaire fill tube leak: Is it just a bad design? (Refrigerator & Freezer Repair)
Belarus bobhucker 6/18/2024 7:59:46 AM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Frigidaire FGHT2055VF - light switch? (Refrigerator & Freezer Repair)
by ranger58 6/13/2024 11:14:06 AM(UTC)
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 6/10/2024 9:18:21 AM(UTC)
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Frigidaire French door temperature (Refrigerator & Freezer Repair)
by Guest 5/28/2024 4:10:07 AM(UTC)
Frigidaire PLHS238ZCB1 Refigerator compressor issues. (Refrigerator & Freezer Repair)
by TonyMertz 5/18/2024 9:32:13 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Frigidaire Gallery dripping through water dispenser (Refrigerator & Freezer Repair)
by cascodo 5/6/2024 9:26:01 PM(UTC)
Frigidaire FFHT1835VB1 Stuck in Defrost Mode (Refrigerator & Freezer Repair)
by dcuozzo 5/6/2024 9:55:29 AM(UTC)
Frigidaire Affinity front loader code (Washer Repair)
by Volusiacrazy 5/1/2024 3:26:17 AM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
Frigidaire fgus2642lf2 auger not getting power (Refrigerator & Freezer Repair)
by knmens 4/15/2024 6:17:43 PM(UTC)
