jose silva
#1 Posted : 10 years ago
jose silva
I HAVE A FRONT LOAD FTF2140es3 when I turn it on it works for 3 seconds and seats for A MINUT RESTART FOR 3 second stops HELP!!!!!
I replaced the top control board, door locker is good, pressure switch,is good, drain pump is good, what else can I do,,PLEASE HELP ME THANK YOU
sidfink43
#2 Posted : 10 years ago
sidfink43
Well darn, that should have fixed it. Use the tech notes inside the lower panel to test the motor/speed control board. But first check all of the wiring and make certain the door lock wiring is okay.
sidfink43
#3 Posted : 10 years ago
sidfink43
Well darn, what you did should have fixed it. Use the tech notes inside the lower service panel to test the motor/speed control board. And make sure the wiring to and from the door lock assembly is good and the connections are tight.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 8 months ago
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 8 months ago
Frigidaire fill tube leak: Is it just a bad design? (Refrigerator & Freezer Repair)
by bobhucker 9 months ago
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 9 months ago
Frigidaire FGHT2055VF - light switch? (Refrigerator & Freezer Repair)
by ranger58 9 months ago
Frigidaire Gallery Refridgerator (Dishwasher Repair)
by Guest 9 months ago
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 9 months ago
Frigidaire French door temperature (Refrigerator & Freezer Repair)
Frigidaire PLHS238ZCB1 Refigerator compressor issues. (Refrigerator & Freezer Repair)
by TonyMertz 10 months ago
Frigidaire oven issue (Dishwasher Repair)
by Guest 10 months ago
Frigidaire Gallery dripping through water dispenser (Refrigerator & Freezer Repair)
by cascodo 10 months ago
Frigidaire FFHT1835VB1 Stuck in Defrost Mode (Refrigerator & Freezer Repair)
by dcuozzo 10 months ago
Frigidaire Affinity front loader code (Washer Repair)
by Volusiacrazy 10 months ago
Frigidaire max load top load washer (Washer Repair)
Frigidaire fgus2642lf2 auger not getting power (Refrigerator & Freezer Repair)
by knmens 11 months ago
