spence43
#1 Posted : Friday, April 3, 2015 7:03:55 AM(UTC)
spence43
Dryer Will Not Heat Untill I Flip Breaker Off And Then Back On.
Then It Dries Fine. Doesn't Require This Reset Everytime.
fairbank56
#2 Posted : Friday, April 3, 2015 7:20:27 AM(UTC)
fairbank56
Groups: Expert
Does the dryer produce heat in Air Dry setting? If so, you probably have a grounded heat element. Otherwise, you may just have a faulty breaker. You would need to check the current draw of the dryer with an amprobe to determine if the dryer is the problem.
Eric
spence43
#3 Posted : Friday, April 3, 2015 3:06:26 PM(UTC)
spence43
dryer does not have air dry cycle
fairbank56
#4 Posted : Friday, April 3, 2015 5:53:15 PM(UTC)
fairbank56
Groups: Expert
Sure it does. Set temp to Air Dry.
Eric
spence43
#5 Posted : Friday, April 3, 2015 6:06:00 PM(UTC)
spence43
Sorry, of course you're right, there is a air dry cycle. Never noticed it, never used it. I tried it and no heat was there. Makes sense that it's probably a faulty breaker. House is 28 years old and most likely so is the breaker. Will try that. Thanks much.
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
Frigidaire Dryer Not Heating - Still Tumbles (Dryer Repair)
by dryerhelp98765 9/18/2021 8:06:29 AM(UTC)
help with samsung dryer not heating : DV350AEW / XAA (Dryer Repair)
by Guest 3/18/2021 11:11:18 AM(UTC)
Kenmore 70 series gas dryer not heating (Dryer Repair)
by Gilmo211 12/29/2020 10:09:04 AM(UTC)
GE Dryer not heating up (Dryer Repair)
by Dryernoob 4/23/2020 10:55:51 AM(UTC)
Dryer Not Heating even tough Fuse and Heating Element is good (Dryer Repair)
by Mixter7958 3/17/2020 4:37:28 PM(UTC)
Dryer not heating, question about voltage drop. (Dryer Repair)
by Pmp816 2/3/2019 6:58:39 AM(UTC)
Amana dryer not heating (Dryer Repair)
by keepingwiththetimes 2/7/2018 2:53:54 PM(UTC)
Whirlpool dryer not heating (Dryer Repair)
by Oscarwray 9/29/2017 4:54:27 PM(UTC)
Maytagdryer Not heating (Dryer Repair)
by ApplianceRN 9/16/2017 12:48:37 PM(UTC)
Dryer not heating (Dryer Repair)
by hoymanj 8/3/2017 2:39:08 PM(UTC)
Maytag Dryer not heating with rattle noise (Dryer Repair)
by Glengc1 6/24/2017 4:09:37 PM(UTC)
Maytag dryer not heating (Dryer Repair)
by Jmr721 4/29/2017 12:11:59 PM(UTC)
Amana Dryer not heating (Dryer Repair)
by HnRmom 4/27/2017 6:09:54 PM(UTC)
by tcdegener@yahoo.com 11/10/2016 8:39:58 AM(UTC)
