Dryer Will Not Heat Untill I Flip Breaker Off And Then Back On. Then It Dries Fine. Doesn't Require This Reset Everytime.
Groups: Expert
Does the dryer produce heat in Air Dry setting? If so, you probably have a grounded heat element. Otherwise, you may just have a faulty breaker. You would need to check the current draw of the dryer with an amprobe to determine if the dryer is the problem.
Eric
dryer does not have air dry cycle
Groups: Expert
Sure it does. Set temp to Air Dry.
Eric
Originally Posted by: spence43 dryer does not have air dry cycle Sorry, of course you're right, there is a air dry cycle. Never noticed it, never used it. I tried it and no heat was there. Makes sense that it's probably a faulty breaker. House is 28 years old and most likely so is the breaker. Will try that. Thanks much.
