Marine2054
#1 Posted : Saturday, March 28, 2015 2:35:41 PM(UTC)
Marine2054
The oven will not work and the oven control or not lit up but the stove top is working
#2 Posted : Sunday, March 29, 2015 1:46:10 AM(UTC)
Does the oven light work.
The elements use the full 240 but the contol board and oven light need 120 volts so perhaps you have lost Neutral.
I would start by checking the power.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Whirlpool Flat Top Stove AND Oven will not work (Oven Repair (including Ranges and Cooktops))
by sonia0865 11/19/2014 6:34:40 AM(UTC)
Heating elements/oven will not work (Oven Repair (including Ranges and Cooktops))
by bobcraycraft 9/15/2013 5:23:18 AM(UTC)
my magic chef range oven will not work (Oven Repair (including Ranges and Cooktops))
by dclary 3/10/2013 11:38:27 PM(UTC)
by rough 7/8/2012 4:43:21 AM(UTC)
Upper Oven will not work. (Oven Repair (including Ranges and Cooktops))
by Dan1612 4/24/2012 3:16:13 PM(UTC)
by emb04 4/18/2011 6:02:13 AM(UTC)
by JohnWiggs 3/10/2011 11:46:16 AM(UTC)
Oven will not work (does not get hot) (Oven Repair (including Ranges and Cooktops))
by newportprof 10/4/2010 9:52:22 AM(UTC)
by Ameryl 12/11/2009 4:59:57 PM(UTC)
Oven will not work period (Oven Repair (including Ranges and Cooktops))
by steakmast3r 8/31/2009 7:32:20 PM(UTC)
by brucewill 6/11/2009 9:11:14 AM(UTC)
Whirpool oven will not work, cooktop works fine (Oven Repair (including Ranges and Cooktops))
by LRN4569 11/17/2008 6:56:45 AM(UTC)
Oven Will Not Work (Oven Repair (including Ranges and Cooktops))
by edturner 10/21/2008 8:36:23 AM(UTC)
Oven will not work when humid outside (Oven Repair (including Ranges and Cooktops))
by DavidJosie 9/13/2008 6:51:14 PM(UTC)
by kal 7/22/2008 2:20:39 PM(UTC)
