Dan1612
#1 Posted : Tuesday, April 24, 2012 3:16:13 PM(UTC)
Dan1612
I have a Maytag Double Gas Oven. The lower oven works fine. All my top burners work fine. But I can not get the upper oven to work. The upper oven and the briler do not work.I replaced the igniter, but that did not fix the problem. I am not getting 120 volts to my igniter.
What should I check next to correct the problem?
Simon / APP Team
#2 Posted : Tuesday, April 24, 2012 4:28:43 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Get the access to the control board and locate contacts 1,2,3,5.
Using the multimeter check red and yellow to the ground.
You should read 0 volts.
Next turn the upper bake and check again(Red.) Then - broil, (Yellow.)
No power - replace the control board.
Control board Part number: 5701M576-60
Here are the breakdown diagrams and Replacement parts for Maytag MGR6772BDS FREESTANDING-DOUBLE OVEN-GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Dan1612
#3 Posted : Saturday, April 28, 2012 8:37:44 AM(UTC)
Dan1612
Thank you so much. I followed your instructions and that was the defective part.
I will definitely use The Repair Help Forum in the future and order all my parts from Appliance Parts Pro.
Simon / APP Team
#4 Posted : Monday, April 30, 2012 9:57:23 AM(UTC)
Simon / APP Team
Groups: APP Team
You are very welcome.
Simon.
