I have a Maytag Double Gas Oven. The lower oven works fine. All my top burners work fine. But I can not get the upper oven to work. The upper oven and the briler do not work.I replaced the igniter, but that did not fix the problem. I am not getting 120 volts to my igniter.
What should I check next to correct the problem?
Groups: APP Team
Hi. Get the access to the control board and locate contacts 1,2,3,5. Using the multimeter check red and yellow to the ground. You should read 0 volts. Next turn the upper bake and check again(Red.) Then - broil, (Yellow.) No power - replace the control board. Control board Part number: 5701M576-60
Thank you so much. I followed your instructions and that was the defective part.
I will definitely use The Repair Help Forum in the future and order all my parts from Appliance Parts Pro.
Groups: APP Team
You are very welcome.
Simon.
