kpholler
#1 Posted : 10 years ago
kpholler
Just replaced heating element, thermostat, thermal limiter, and thermistor control and the dryer still will not heat up! Could the problem be in the control panel or is there any other options?:confused:
#2 Posted : 10 years ago
Here are your parts, includes a wiring diagram.
Parts for Frigidaire LEQ2152EE0 Dryer - AppliancePartsPros.com
Here is a tech sheet.
http://manuals.frigidaire.com/p...Webster/134509400efs.pdf
Could be the control board or the centrifugal switch on the motor.
But the first thing to check is the power.
The board, motor and drum light all use half the line (120 volts) but the heater coil requires the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10 years ago
Maytag Centennial dryer will not heat up (Dryer Repair)
by 1hkfan 12 years ago
Dryer will not Heat up (Dryer Repair)
by jasmineblue27 13 years ago
Dryer will not heat up consistently (Dryer Repair)
by GPDIY 13 years ago
Electric Dryer will not heat up (Dryer Repair)
by varn99 14 years ago
by ray2 14 years ago
by Raljac63 15 years ago
Whirlpool Kirkland Gas Dryer Will Not Heat Up (Dryer Repair)
by LITTLE RED ROOSTER 15 years ago
Kenmore Dryer Will Not Heat Up (Dryer Repair)
by mastaone 15 years ago
Dryer will not heat up? (Dryer Repair)
by mel1293 16 years ago
by Steve T 16 years ago
by clemmy 16 years ago
Dryer Will Not Heat Up - Plug Changed recently from 4 to 3 prong (Dryer Repair)
by Seeking Help 16 years ago
Maytag Gas Dryer will not heat up fully - princeton (Dryer Repair)
by brian.frasco@gmail.com 16 years ago
Whirlpoool dryer will not heat up (Dryer Repair)
by ayellis 17 years ago
