My Kenmore dryer will not heat up. The dryer works great otherwise. Can you help me with this problem?
Thanks,
Steve, The first thing I would do is check if there is 240 VAC to the dryer. The heater need 240 VAC while 120 VAC is good enough for the motor and the timer. If there is nothing wrong then perform the troubleshooting as described in the Service manual. Post the results and we will help you with the correct part numbers. Gene.
