My dryer will not heat up and I need some help.
To get to the heating element on most of these dryers you remove the back dust cover: 1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat. 2. Heater assembly. 7. Control thermostat(s). 5. Fuse(350F), if blown(open) the dryer will NOT run. 4. Heater element.
