2 Pages12>
metropical
#1 Posted : Friday, November 7, 2014 6:47:45 AM(UTC)
metropical
figured I'd check for stopped drain in the DW first as we have no disposal in the sink.
got the baskets and prop out.
But the feed tube assy has no screws. Does it just pull out or slide or ....?
#2 Posted : Saturday, November 8, 2014 2:20:52 AM(UTC)
Here are your parts.
If you click on a part's description of picture a new page will open with additional info, often a Q&A section that may be helpful.
Parts for KitchenAid KUDS02FSPA3 Dishwasher - AppliancePartsPros.com
The following may also help.
You have to join the site and be logged in to be able to download it.
metropical
#3 Posted : Saturday, November 8, 2014 4:48:01 AM(UTC)
metropical
thanks very
#4 Posted : Saturday, November 8, 2014 6:10:04 AM(UTC)
OOPS!!!
Looks like I did not give you the link to the manual so here it is.
http://appliancejunk.com...wnloads;sa=view;down=234
Sorry about that.
metropical
#5 Posted : Saturday, November 8, 2014 6:37:17 AM(UTC)
metropical
thanks for the manual.
metropical
#6 Posted : Wednesday, November 12, 2014 7:50:48 AM(UTC)
metropical
in re-assembling the dw, I don't recall if the lower spray arm rocked a little on it's axel as it is now.
Should there be a little play
#7 Posted : Wednesday, November 12, 2014 9:29:39 AM(UTC)
Yes it will be a litte loose
metropical
#8 Posted : Wednesday, November 12, 2014 6:05:05 PM(UTC)
metropical
well cleaning the drain, sump and chopper didn't do it.
still water in the tub
dishes are clean.
I think the LED was flashing twice, but I rushed to empty the tub with the held Cancel button, so I may have been wrong, but at least twice.
#9 Posted : Thursday, November 13, 2014 1:56:28 AM(UTC)
Does it at least drain some water re: the drain pump is running when it should.
If it does then it could be a problem with the drain pump.
metropical
#10 Posted : Sunday, November 16, 2014 6:48:11 AM(UTC)
metropical
update: ran today. Failed after the tub filled.
the LED was single flashing, constantly and the door was ajar.
no soap was dispensed.
Float switch assy next?
I can empty the tub by holding cancel a few secs and closing.
2 Pages12>
