figured I'd check for stopped drain in the DW first as we have no disposal in the sink. got the baskets and prop out. But the feed tube assy has no screws. Does it just pull out or slide or ....?
THIS FORUM IS DEAD!!!!!!! |
in re-assembling the dw, I don't recall if the lower spray arm rocked a little on it's axel as it is now. Should there be a little play
Yes it will be a litte loose |
well cleaning the drain, sump and chopper didn't do it. still water in the tub dishes are clean. I think the LED was flashing twice, but I rushed to empty the tub with the held Cancel button, so I may have been wrong, but at least twice.
Does it at least drain some water re: the drain pump is running when it should.
If it does then it could be a problem with the drain pump. |
update: ran today. Failed after the tub filled. the LED was single flashing, constantly and the door was ajar. no soap was dispensed.
Float switch assy next?
I can empty the tub by holding cancel a few secs and closing.
