pfeffern
#1 Posted : Sunday, October 19, 2014 4:32:07 PM(UTC)
pfeffern
I've got a GE top loading washer that won't stop filling. The washer has a choice of load size (small, large, super), and it won't fill at all unless the load size is set to super. If it is set to super it will just keep filling and then eventually the washer will overflow. However, if I turn the load size selection back down to small (where it doesn't usually fill) the filling will stop, and the cycle will continue as normal and it will drain and spin properly. I think it may be an issue with the knobs that are used to select the settings as they are in terrible condition.
I'd greatly appreciate any help!
fairbank56
#2 Posted : Sunday, October 19, 2014 6:29:06 PM(UTC)
fairbank56
Groups: Expert
Sounds like a faulty water level pressure switch but I would first check the pressure hose and air dome on the lower left side of the outer tub. You have to remove the front panel for access. With tub empty of water, disconnect the hose from the air dome and clean out any gunk in the hose and flush out any gunk in the air dome using a turkey baster and hot water. Be careful as you don't want to break the hose nipple off of the air dome. The air dome is not removable. If the hose and/or air dome are not gunked up, then replace the switch which is behind the user control panel and is controlled by the user water level control knob.
GE WH12X10065 Water Level Switch - AppliancePartsPros.com
Eric
Washer won't stop filling (Washer Repair)
by sundbergjc 3/5/2018 8:16:31 AM(UTC)
by bombay71 5/27/2017 2:19:25 PM(UTC)
GE washer won't stop filling, agitate or spin (Washer Repair)
by nmoreno24 10/14/2016 6:57:55 PM(UTC)
maytag washer won't stop filling up (Washer Repair)
by aswright33 7/13/2014 11:15:42 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
washer won't stop filling (Washer Repair)
by Becki Meek 12/27/2012 11:54:31 AM(UTC)
Maytag Washer won't stop filling (Washer Repair)
by wjpcohen 5/21/2012 9:11:31 AM(UTC)
Kenmore Elite Washer won't stop filling on cold cycles (Washer Repair)
by pgast2 4/1/2012 4:47:22 PM(UTC)
Frigidaire Washer Won't Stop Filling Up (Washer Repair)
by hntpilcher 2/23/2012 12:59:23 PM(UTC)
Maytag Washer Won't Stop Filling (Washer Repair)
by klunker 7/26/2011 10:26:38 AM(UTC)
by craigwebster375 7/25/2011 3:23:21 PM(UTC)
whirlpool washer won't stop filling (Washer Repair)
by magicLV 7/12/2011 1:08:23 PM(UTC)
by kimbovia 5/31/2011 6:40:01 AM(UTC)
by alohatech 5/18/2011 12:32:33 AM(UTC)
Washer won't stop filling up (Washer Repair)
by CarlaS 2/22/2011 7:50:19 AM(UTC)
