The washing machine won't stop filling regardless of what size load is selected. I think it is the Water Level Switch, but I am not sure. I can turn the water off by turning the control switch (timer) to off, or pushing the knob in. I have checked the air tube & it seems to be OK. Thanks.
Hello klunker. Based on the information you provided, it sounds like the pressure switch is bad and will need to be replaced. As long as the hose is good, and is not clogged, you will need to replace the pressure switch. Hope this helps. Part number: AP4025434
