klunker
#1 Posted : Tuesday, July 26, 2011 10:26:38 AM(UTC)
klunker
The washing machine won't stop filling regardless of what size load is selected. I think it is the Water Level Switch, but I am not sure. I can turn the water off by turning the control switch (timer) to off, or pushing the knob in. I have checked the air tube & it seems to be OK. Thanks.
Jeff / APP Team
#2 Posted : Tuesday, July 26, 2011 10:30:39 AM(UTC)
Jeff / APP Team
Hello klunker. Based on the information you provided, it sounds like the pressure switch is bad and will need to be replaced. As long as the hose is good, and is not clogged, you will need to replace the pressure switch. Hope this helps.
Part number: AP4025434
maytag washer won't stop filling up (Washer Repair)
by aswright33 7/13/2014 11:15:42 AM(UTC)
Maytag Washer won't stop filling (Washer Repair)
by wjpcohen 5/21/2012 9:11:31 AM(UTC)
by craigwebster375 7/25/2011 3:23:21 PM(UTC)
Maytag Washer Won't Stop Filling (Washer Repair)
by rinmarie2002 12/22/2009 6:04:14 AM(UTC)
