had a PF code i reset it but dryer wont turn on when press start.cycle lights up but wont start
Groups: Expert
Check for broken belt. Otherwise, check continuity on thermal fuse. Check for 120vac at thermal fuse when start button pressed. If voltage good, check continuity on belt switch. Continuity checks with dryer unplugged.
Eric
