smcacken
#1 Posted : Wednesday, August 13, 2014 11:28:32 AM(UTC)
smcacken
Our whirlpool refrigerator and freezer is not cooling..the evaporator motor and fan are running. Could it be the start relay for compressor? the refrigerator runs and all lights work. We had a power surge recently"
#2 Posted : Thursday, August 14, 2014 2:00:30 AM(UTC)
Parts for Whirlpool ED25LFXGN00 Refrigerator - AppliancePartsPros.com
[COLOR="Blue"]the evaporator motor and fan are running.[/COLOR]
I am assuming you mean the evaporator/freezer fan and the condenser/compressor fan are both on.
[COLOR="Blue"]
Could it be the start relay for compressor? the refrigerator runs[/COLOR]
Check if the compressor is on.
It should be on whenever the fans are on (they are wired in parallel).
You can usually hear it but also should be able to feel it vibrating.
If it is on and you get no or little cooling then it is a sealed system problem.
This will be an expensive repair.
If it is not on then check the compressor windings, see the below link.
Also see the info on the start device.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
If the windings are good then it is worth while trying a new start device which is often the only reliable way to tell if it is the culprit.
Note that the compressor winding test can tell you if a compressor is bad but does not tell you that it is good as it may have other internal problems.
File Attachment(s):
ED25LF.pdf (157kb) downloaded 2 time(s).
Fridge wont cool, Due to clogged lines (Refrigerator & Freezer Repair)
by Engineco24 12/24/2014 2:06:16 PM(UTC)
Freezer and fridge wont cool (Refrigerator & Freezer Repair)
by jeffreyhnatch1 6/24/2013 7:46:52 AM(UTC)
GE Profile Side by Side Freezer & Frig Wont Cool (Refrigerator & Freezer Repair)
by dwilli35 6/3/2013 9:11:38 PM(UTC)
Fridge/freezer wont cool (Refrigerator & Freezer Repair)
by Dono 3/29/2013 12:51:21 PM(UTC)
Freezer Working But Fridge Wont Cool (Refrigerator & Freezer Repair)
by michael jr 3/7/2013 5:41:17 PM(UTC)
freezer sat unplugged now wont cool (Refrigerator & Freezer Repair)
by tsonny 7/11/2012 3:43:58 PM(UTC)
Bought refrigerator wont cool and i smell freon leaking. (Refrigerator & Freezer Repair)
by Tressa1 3/23/2012 6:15:11 AM(UTC)
Maytag wont cool (Refrigerator & Freezer Repair)
by diamond-x 2/8/2012 7:18:17 PM(UTC)
by erich67 2/8/2012 5:35:54 PM(UTC)
Freezer wont cool but fridge cools (Refrigerator & Freezer Repair)
by Kenoo 10/27/2011 8:20:35 PM(UTC)
Refrigerator wont cool (Refrigerator & Freezer Repair)
by Sinchak59 5/15/2011 12:49:56 PM(UTC)
GE Bottom Freezer wont cool, has white powder (Refrigerator & Freezer Repair)
by jpaul18535 5/12/2011 6:32:26 PM(UTC)
GE Freezer is it proper temps but Fridge wont cool past 42F (Refrigerator & Freezer Repair)
by jcl3042 12/15/2010 4:26:35 PM(UTC)
refrigerator laid on it side and wont cool (Refrigerator & Freezer Repair)
by danj217 11/21/2010 6:44:56 AM(UTC)
Fridge slowly died, wont cool, hot compressor (Refrigerator & Freezer Repair)
by 321break 9/14/2010 8:33:05 PM(UTC)
