Alcom
#1 Posted : Tuesday, August 12, 2014 6:11:35 PM(UTC)
Alcom
One circuit breaker gets hot, both CBR open after dryer w/heat runs ~10 min. Dryer will run on no heat cycle. Have not opened cabinet.
#2 Posted : Wednesday, August 13, 2014 1:01:45 AM(UTC)
Parts for Whirlpool WED5800SG0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Could be that you have a grounded element.
Unplug the unit and both wires from the heater element.
Measure the element, should be around 8 to 12 ohms.
Then measure from each element connector to the case, both should be infinite ohms.
If not the element is grounded and should be replaced.
File Attachment(s):
WED5800.pdf (261kb) downloaded 2 time(s).
Washer pops circuit breaker (Washer Repair)
by Alexiared 11/6/2023 3:37:16 PM(UTC)
Whirlpool rs6105xyn7 range keeps tripping circuit breaker with flash of light (short) (Oven Repair (including Ranges and Cooktops))
by deancuebas 3/27/2022 9:04:07 PM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Dishwasher trips main circuit breaker (Dishwasher Repair)
by davebro10 12/26/2016 7:37:35 AM(UTC)
Tripping circuit breaker (Oven Repair (including Ranges and Cooktops))
by master54handyman 11/27/2014 1:23:12 PM(UTC)
Circuit breaker keeps tripping (Dryer Repair)
by Johhar23 9/2/2014 2:11:37 AM(UTC)
Oven tripping circuit breaker (Oven Repair (including Ranges and Cooktops))
by CBTaylor 4/14/2014 8:23:37 AM(UTC)
by paulrk 2/25/2014 12:46:51 PM(UTC)
HELP! Dryer keeps tripping circuit breaker. (Dryer Repair)
by Lloydj 1/29/2014 1:11:42 PM(UTC)
Dryer cyles, no heat, trips circuit breaker leg (Dryer Repair)
by kwillie 1/1/2014 3:07:19 PM(UTC)
GE profile gas range trips circuit breaker (Oven Repair (including Ranges and Cooktops))
by Parkhillycarl 8/30/2013 2:31:44 PM(UTC)
Dryer trips circuit breaker for heat (Dryer Repair)
by yoshica 7/28/2013 12:36:45 PM(UTC)
Door closing trips circuit breaker. (Microwave Repair)
by Seawolf 5/19/2013 12:37:30 PM(UTC)
Jenn-Air oven trips the circuit breaker (Oven Repair (including Ranges and Cooktops))
by emgeier 5/12/2013 11:11:27 AM(UTC)
electric dryer shut off/trips circuit breaker (Dryer Repair)
by smilley1 1/3/2013 8:13:59 PM(UTC)
