Alcom
#1 Posted : 11 years ago
Alcom
One circuit breaker gets hot, both CBR open after dryer w/heat runs ~10 min. Dryer will run on no heat cycle. Have not opened cabinet.
#2 Posted : 11 years ago
Parts for Whirlpool WED5800SG0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Could be that you have a grounded element.
Unplug the unit and both wires from the heater element.
Measure the element, should be around 8 to 12 ohms.
Then measure from each element connector to the case, both should be infinite ohms.
If not the element is grounded and should be replaced.
File Attachment(s):
WED5800.pdf (261kb) downloaded 2 time(s).
Washer pops circuit breaker (Washer Repair)
by Alexiared about a year ago
Whirlpool rs6105xyn7 range keeps tripping circuit breaker with flash of light (short) (Oven Repair (including Ranges and Cooktops))
by deancuebas 3 years ago
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 7 years ago
Dishwasher trips main circuit breaker (Dishwasher Repair)
by davebro10 8 years ago
Tripping circuit breaker (Oven Repair (including Ranges and Cooktops))
by master54handyman 10 years ago
Circuit breaker keeps tripping (Dryer Repair)
by Johhar23 11 years ago
Oven tripping circuit breaker (Oven Repair (including Ranges and Cooktops))
by CBTaylor 11 years ago
by paulrk 11 years ago
HELP! Dryer keeps tripping circuit breaker. (Dryer Repair)
by Lloydj 11 years ago
Dryer cyles, no heat, trips circuit breaker leg (Dryer Repair)
by kwillie 11 years ago
GE profile gas range trips circuit breaker (Oven Repair (including Ranges and Cooktops))
by Parkhillycarl 12 years ago
Dryer trips circuit breaker for heat (Dryer Repair)
by yoshica 12 years ago
Door closing trips circuit breaker. (Microwave Repair)
by Seawolf 12 years ago
Jenn-Air oven trips the circuit breaker (Oven Repair (including Ranges and Cooktops))
by emgeier 12 years ago
electric dryer shut off/trips circuit breaker (Dryer Repair)
by smilley1 12 years ago
