master54handyman
#1 Posted : Thursday, November 27, 2014 1:23:12 PM(UTC)
master54handyman
50 amp breaker trips during oven operation. Replaced breaker, same problem. Unit should operate on 40 amp breaker. Top and bottom elements operate in bake mode.
#2 Posted : Friday, November 28, 2014 3:18:11 AM(UTC)
Parts for RF362LXSS - AppliancePartsPros.com
Not sure what is going on.
Are both elements on at the same time when in bake?
They should not be.
They should switch back and forth.
Even if they are both on at the same time they should only pull around 25 amps. So the breaker should not trip unless you also have stove top elements on.
Do both elements heat evenly along their length?
If not it may be a bad element.
I would check the connections at the wall receptacle and the terminal strip in the unit.
Be sure that the power is Off when doing this.
File Attachment(s):
RF362.pdf (125kb) downloaded 4 time(s).
master54handyman
#3 Posted : Sunday, November 30, 2014 6:16:58 AM(UTC)
master54handyman
Originally Posted by: denman Go to Quoted Post
They should not be.
Thanks this makes more sense than any of the other posts. I'll let you know what I find.
Whirlpool rs6105xyn7 range keeps tripping circuit breaker with flash of light (short) (Oven Repair (including Ranges and Cooktops))
by deancuebas 3/27/2022 9:04:07 PM(UTC)
Oven tripping circuit breaker (Oven Repair (including Ranges and Cooktops))
by CBTaylor 4/14/2014 8:23:37 AM(UTC)
HELP! Dryer keeps tripping circuit breaker. (Dryer Repair)
by Lloydj 1/29/2014 1:11:42 PM(UTC)
error code f09&tripping circuit breaker (Washer Repair)
by yirga29 2/8/2011 1:01:03 PM(UTC)
Sears gas dryer tripping circuit breaker (Dryer Repair)
by dwawayne 1/14/2011 1:55:11 PM(UTC)
Range tripping circuit breaker, but only intermittently (Oven Repair (including Ranges and Cooktops))
by AlloyGT 11/26/2008 10:35:40 PM(UTC)
