goatlady7
#1 Posted : 11 years ago
goatlady7
mY DRYER would not stop running on the auto dry and wrinkle control settings, but it would dry. Now it won't dry on the times cycle. What parts do I need to fix this? Thanks for your help.
#2 Posted : 11 years ago
Here are your parts includes a wiring diagram
Parts for Maytag MDE2706AYW Dryer - AppliancePartsPros.com
You will have to do some troubleshooting as no heat can be caused by a number of things.
It may or may not be related to your earlier problem of no timer advancing.
Unplug the unit and check the heating element, should be around 8 to 12 ohms.
Check the hi-limit thermostat, should be 0 ohms.
Check the cycling thermostat BU to PU should be 0 ohms.
amana cloth dryer ned4600yq1 dryer help heating (Dryer Repair)
by darmentle 3 years ago
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 3 years ago
Samsung Dryer Help Needed (Dryer Repair)
by JMichael88 7 years ago
Whirlpool dryer help (Dryer Repair)
by mforesta 7 years ago
Dryer help please (Dryer Repair)
by Juliebolson 8 years ago
LOUD DRYER HELP! Video (Dryer Repair)
by kyle_couillard 8 years ago
LG Gas Dryer HELP (Dryer Repair)
by jdm99prelude 9 years ago
by Jenjudd2 10 years ago
Frigidaire dryer help (Dryer Repair)
by pro69 11 years ago
by lola78 11 years ago
Estates Dryer HELP (Dryer Repair)
by cblakem02 11 years ago
GE Dryer help needed. (Dryer Repair)
by rad_rob 11 years ago
Maytage Bravos Quiet Series 300 Dryer Help (Dryer Repair)
by zfreeman 11 years ago
Electric Dryer Help Needed!!!! (Dryer Repair)
by redneckchevy9 11 years ago
Kenmore Dryer Help (Dryer Repair)
by diy'er 11 years ago
