ajlgap19
#1 Posted : Friday, June 6, 2014 9:55:32 AM(UTC)
ajlgap19
Dryer heating element remains on if you were to open dryer door with timer still on. have replaced all fuses and thermostats. still no help !!! will run for a while before it blows fuse.
#2 Posted : Tuesday, June 10, 2014 3:26:51 AM(UTC)
Parts for Whirlpool WED4900XW0 Dryer - AppliancePartsPros.com
I am assuming that when you open the door that the motor stops.
Could be a couple things.
Unplug the unit and both wires from the heating element.
Measure across the heating element, should be around 8 to 12 ohms.
Then measure from each side of the eelement to the case, both should be infinite ohms. if not the element is grounded and should be replaced.
If the element is good then you will see that there is a centrifugal switch on the motor which closes when the motor gets close to operating speed.
When the motor is at rest it should be open killing power to the heating coil.
Could be it is stuck in the closed position or it's contacts are welded together.
If it is a bad switch then the motor will have to be replaced.
Whirlpool electric dryer m#ler4631bq1 (Dryer Repair)
by Guest 6/8/2022 5:45:29 AM(UTC)
Whirlpool electric dryer trouble (Dryer Repair)
by sometime fixer 9/26/2018 9:11:22 AM(UTC)
Whirlpool electric dryer heating safety issues (Dryer Repair)
by Pirate111 10/8/2017 9:57:09 AM(UTC)
wHIRLPOOL eLECTRIC dRYER (Dryer Repair)
by jjmoore 3/21/2015 9:53:19 AM(UTC)
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 1/22/2015 9:10:42 AM(UTC)
Whirlpool Electric Dryer not stopping and not heating (Dryer Repair)
by rschunk 1/23/2014 7:03:27 PM(UTC)
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 1/16/2014 9:02:04 AM(UTC)
Whirlpool Electric Dryer No Heat (Dryer Repair)
by ahrjmrecr 10/30/2013 2:38:30 PM(UTC)
whirlpool electric dryer (Dryer Repair)
by eisehunter 5/28/2013 1:44:53 PM(UTC)
Whirlpool Electric Dryer - Runs- No Heat! (Dryer Repair)
by Steveorageous 2/6/2013 12:59:47 PM(UTC)
Whirlpool Electric Dryer (Dryer Repair)
by mayork 11/14/2012 10:21:04 AM(UTC)
Whirlpool Electric Dryer, replaced timer, will not advance (Dryer Repair)
by muttonchop 9/10/2012 2:08:11 PM(UTC)
Whirlpool Electric Dryer not getting hot (Dryer Repair)
by jonrob65 8/20/2012 12:48:36 PM(UTC)
Whirlpool Electric Dryer heating on Air Only (Dryer Repair)
by quigleybmd 8/18/2012 1:10:17 PM(UTC)
Whirlpool electric dryer too hot (Dryer Repair)
by Fixnitmyself 5/16/2012 12:36:00 PM(UTC)
