mmanning
#1 Posted : Wednesday, April 9, 2014 5:22:37 AM(UTC)
mmanning
The alarm came on and the top 2 shelves are not freezing as solid as bottom of freezer is. Both the orange and red indicator lights are on. The freezer has been making loud bumping noises sparatically for a few weeks past.
#2 Posted : Wednesday, April 9, 2014 6:44:13 AM(UTC)
Here are your parts.
Parts for Frigidaire LFFH2067DW1 Freezer - AppliancePartsPros.com
Is the evaporator/freezer fan on when the door switch is held closed?
If the fan is not working the warm air will rise in the cabinet.
Is the compressor on?
You can usually hear it but should also be able to feel it vibrating?
If on is it cycling normally or is it on all the time?
If it is on remove the cover in the freezer to inspect the evaporator coils.
If they are heavily frosted/iced over you may have a defrost problem.
The compressor will probably run all the time except when it goes through a defrost cycle.
If there is just frost in one area (usually where the freon enters the coils) it could be a sealed system problem. The compressor will also run all the time.
I am not sure what the bumping noise is.
Sometimes if there is a mechanical problem with the compressor there will be a bang when the compressor shuts off.
May just be a bad compressor mount so I would check them.
Frigidaire upright freezer to warm (Refrigerator & Freezer Repair)
by jrklund311 1/11/2024 2:51:18 PM(UTC)
Frigidaire upright freezer temperature display acting strangely (Refrigerator & Freezer Repair)
by redroverguy 1/1/2024 11:34:30 AM(UTC)
Frigidaire upright freezer model FFFH17F2QWA (Refrigerator & Freezer Repair)
by Guest 4/6/2023 11:29:17 AM(UTC)
Frigidaire Upright Freezer Misbehaving (Refrigerator & Freezer Repair)
by sun_lover 3/23/2023 12:32:46 PM(UTC)
Green Light at bottom front of Frigidaire upright freezer (Refrigerator & Freezer Repair)
by Guest 9/7/2022 10:43:50 PM(UTC)
Frigidaire upright freezer runs for several hours then shuts off (Refrigerator & Freezer Repair)
by Guest 7/21/2021 11:32:11 AM(UTC)
Frigidaire Upright Freezer (FFH17F7H) showing wrong temperature (Refrigerator & Freezer Repair)
by Guest 7/21/2021 6:21:52 AM(UTC)
Frigidaire upright freezer not working (Refrigerator & Freezer Repair)
by Hsalbeck 2/10/2017 12:05:48 PM(UTC)
Dead Frigidaire upright freezer (Refrigerator & Freezer Repair)
by danjr64 8/25/2016 11:29:49 AM(UTC)
Frigidaire Upright Freezer not Freezing (Refrigerator & Freezer Repair)
by HHousehold 9/15/2014 10:11:57 PM(UTC)
by Marlbec88 8/27/2014 7:59:53 AM(UTC)
Frigidaire upright freezer cycles from -2 to 35 (Refrigerator & Freezer Repair)
by MartyD12 8/18/2014 7:07:23 AM(UTC)
Frigidaire Upright Freezer Gasket (Refrigerator & Freezer Repair)
by paul.d.weir@gmail.com 7/10/2014 7:40:04 AM(UTC)
Frigidaire upright freezer alarms (Refrigerator & Freezer Repair)
by Spydrfly 3/16/2014 6:39:35 AM(UTC)
Frigidaire upright freezer problem (Refrigerator & Freezer Repair)
by stephen01 11/19/2013 1:08:44 PM(UTC)
