danjr64
#1 Posted : Thursday, August 25, 2016 11:29:49 AM(UTC)
danjr64
Freezer interior light come on indicator lights still light no other signs of life no noise has been unplugged long enough to have defrosted
Ahhnother8
#2 Posted : Monday, August 29, 2016 9:44:33 AM(UTC)
Ahhnother8
Same appliance with the same problem. It simply shut off and will not restart.
Ahhnother8
#3 Posted : Monday, September 5, 2016 6:25:06 PM(UTC)
Ahhnother8
I turned the dial on the defrost timer and also turned the thermostat to the off position and then back on. It came back to life, but I still replaced the thermostat, as that seemed like the only thing that was questionable.
cbmserviceguy
#4 Posted : Tuesday, September 6, 2016 7:06:07 AM(UTC)
cbmserviceguy
Manually turn the defrost timer to make sure it's not stuck in defrost. If not stuck in defrost, check t-stat to make sure it's supplying current for the compressor. Replace which ever one isn't functioning properly.
